It's obvious if one thinks about it for a few milliseconds: if the PRO-107's "RRDB format" is documented/released, or if the software supported copy/paste, then Lindsay doesn't get many more premium subscriptions - everyone would have easy access to the current (well, at most 7 days old) USA RRDB data for free.
That's nonsense, how would an import from csv give away any of the RR frequencies, I want to import frequencies not export.
I had read the manual before purchase and had noted:-
You can then use the iSCAN PC Application to:
• Update the Library
• Edit iSCAN’s configuration and stored objects
But they actually mean you can update a library / edit stored objects which is a subset of RR and not your own choice, for your own library you have to enter the objects by hand one at a time.
Object capacity..................................................................... > 10 million,
Nominal, with 2 GB SD Card
Varies depending on user configuration
Again it doesn't say is its up to 10 million objects of someone elses subset and not the users objects unless you want to key them all in manually!
I realise that this was my wrong interpretation of the manual but this is most certainly NOT a way forward for scanners, its so locked down its just stupid.
