N4GKS
I can't get the scanner to upload the software frequencies becasue the scanner won't connect to the computer. Any suggestions?
Frequencies aren't "uploaded" to the PRO-107, and the PRO-107 does not "connect" to the computer (except for firmware updates).
To transfer the frequencies and other data that you've programmed in the PRO-107 PC software, you must remove the SD Card from the scanner, put it in a "card reader" attached to the computer, copy the files over via the software's menu items, then put the card back into the scanner.
Could it be that DonS answered your question before you asked it when he wrote "the PRO-107 does not "connect" to the computer (except for firmware updates)."Then why does it come with a cable for the computer to the scanner?
IMHO, and again IMHO, Radio Shack/GRE should have made the swapping of the SD card easier than taking the back cover off and then the batteries out. Perhaps they might have put it on the side of the scanner.
The placement of the SD Card on the PRO-107 was intentional. It was intended to make it more difficult to remove the card while the scanner is powered "on" - there's a bunch of cached data and, if the card is removed before that data is written, you're guaranteed of file system corruption. It's roughly equivalent to yanking AC power from your desktop computer while it's busy manipulating several files on a FAT hard drive.
