jfhtm350
I have read the manual (although not too informative) and done some research here on the internet and I have some questions to ask. Maybe somebody can help me out.
I want to program the Knox County Public Safety (Motorola Type II Smartnet) Trunking System in my Pro-164. Knoxville/Knox County Public Safety Trunking System, Knoxville, Tennessee - Scanner Frequencies
I am going to program it into bank 7, an empty bank.
1) Ok, so i need to set my bank type to Motorola Trunking mode.
2) Set the 800mhz system type (normal or splinter).
3) I do not need to fool with the base, offset and step settings since it is only 800mhz right?
4) I do not need to fool with the motorola type I fleetmap settings right? all the blocks are set on type 2
Now if the trunking bank is setup correctly:
1) Program the control channel into channel 700. (854.41250c)
2) Progam the talkgroups into the subbanks i want to listen to and set the bank closed. ( I just want to listen to certain ones Police,Fire)
3) Done and Scan.
Question 1: Is the above the correct way to program it?
Question 2: Are the Alternate control channels voice channels when the primary control channel is working or are they control channels all the time?
Question 3: If I dont set the bank closed to what i want to listen to, will it just track the first person that shows up on the control channel until they are done talking and then go back to the control channel and repeat?
I live in the next county over and im getting a blotchy signal from the primary control channel so i cant really test my settings to see if everything is working. But i want everything to be working properly for when i visit Knox County.
3) Done and Scan.
