Typically you use a cable that connects to the USB port on your PC and plugs into the PC/IF jack on the scanner. The cable will require a driver. With the cable installed go to Device Manager and you'll see the Com port there. I usually load Device Manager first, look at the Ports; then plug in the cable and see what is new.
