If type is P25 Auto, T-Tables will auto populate.Yes. Is Virginia State Police DVRS Vehicle Repeater Freq's included in the STARS download? i'm in the warrenton area. Do I need to make sure I have specfic towers or T-Tables. Do I need to make any adjustments to the data downloaded from RR? Thank you for any help!
Then you don't have a correct control frequency (CC) in TSYS frequencies or you are to far from the tower to decode the data.P25 auto is set. When I look at "edit T Tables" the table is blank
Great, you should now be able to find 8 T-Tables for STARS TSYS.Thanks for your help!
I pick-up Fauquier Co. and Prince William Co. just fine.
FMOM had it right about VSP "you are to far from the tower to decode the data". For some reason the PRO-197 scanner would not pick-up VSP while sitting in my house. I took the scanner for a ride in my car. I drove R28 from the Bealeton area up to the PWC line. By the time I got to Catlet I was picking up VSP from Richmond, Culpeper & Fairfax. I guess it just needed to decode. Everything seem to be working just fine now.
