Pro-197 newbie
quadro
Very new to scanner world and needing help on how to be able to pick up channels that were programmed by Scanner Master. What do I need to do to? Thanks
rk911
Rich
Wheaton, IL
what do you mean by..."...how to be able to pick up channels that were programmed by Scanner Master. What do I need to do to?"
are you scanning those frequencies and not hearing anything?
are those frequencies not beinb scanned?
rich
tvengr
Well Known Member
Baltimore County, MD
What is your city, county, and state? I will check on what is available to monitor. You can do your own programming with software. I use Butel ARC500 for programming my Pro-197. You have to turn on the proper scan lists to monitor what is programmed in the scanner. 1 thru 0 on the keypad toggles scan lists 1 thru 10 on and off. If you press FUNC first, 1 thru 0 toggles scan lists 11 thru 20.
