JohnDavid
I turned on my scanner today and it has absolutely no signal?? Ive hooked up three different attennas and nothing. tried reload freqs and nothing. what is going on?
im baffled.. all my conventional freqs work well. ive updated the firmware and rewritten everything. still nothing. everything in the circuit board looks fine help!
The scanner shows just an "S" in the signal bar. Conventional freqs work fine. (I left that out in my dramatically different statement bc I only scan trunking systems) the scanner has been in my patrol car for 6 months and worked fine. I listen to the burdette tower. I've reset the scanner completely. And reprogrammed it using rr. Still nothing.
ive analyzed it and it brings up the control channel, starts static, and doesnt give me the lat and long like it used to. its not getting any data from the tower at all. but its not the antenna?? what else could it be?
i believe the mississippi country burdette tower has changed. i switched to another tower and its picking up the data. so its not the radio. how would i get updated freqs for that tower?
