Howdy Yall, just got my PRO-197, first digital scanner and first one I've NOT programmed by hand. Initially, as I added each set of channels (IE all local FD channels) from rr.com (premium), even though they are under the same P25 system (TxWARN), it created that TGRP as if it was a new, different system. Therefore I have 15 instances of the same TxWARN P25 system, each with different talkgroups associated with them.
For ease of labeling, I changed the label of each system to more accurately describe the talkgroups I have under them. If I were to move them all back into the same system (forfeiting my fancy labels), would the scanner run through the talkgroups more quickly? My problem is it takes 5-10 seconds to loop around back to the one single channel that I want to ALWAYS hear.
Thanks!
Thanks!
