.I am new to this. My question is. When I program a frequency into my scanner and hit scan it says nothing enabled. What am I doing wrong? I used Arc500 and it won't pick anything up. Please help. I am getting frustrated.
I own the same scanner as you and the videos that helped me learn how to use the scanner is this oneI am new to this. My question is. When I program a frequency into my scanner and hit scan it says nothing enabled. What am I doing wrong? I used Arc500 and it won't pick anything up. Please help. I am getting frustrated.
I am trying to get the police fire and ems and t airport. My city is Middletown Pa 17057 County. I'm not sure what you me by a gr5 programming. Could you give me the steps to do that. ThanksI use ARC500 also. If you attach your gr5 programming file, I will check it for errors. You will need to right click on the file and Send to Compressed (zipped) folder to be able to attach it. Click on Attach files and open the zipped folder. What is your city, county, and state, and which systems and agencies are you trying to monitor? What programming cable are you using? If you go to the Scanner tab in ARC500 and click on Install USB Driver, it will install a generic driver which may work with your cable if you haven't done so already.
sorry Dauphin countyI am trying to get the police fire and ems and t airport. My city is Middletown Pa 17057 County. I'm not sure what you me by a gr5 programming. Could you give me the steps to do that. Thanks
The file that you send to the scanner to program it has an extension of .gr5. The steps for attaching the file are in my previous post #4.I'm not sure what you me by a gr5 programming. Could you give me the steps to do that. Thanks
