Pro 2035 Help
CharlesDom
I've had a Pro 2035 for a number of years but I haven't used it for a while. I also installed an OS535 card in it. The scanner still works fine and hopefully so does the interface card. When I used it back then, it was a great scanner. The problem is I'm not sure what software to use that is compatible with Windows XP. Back then I used Windows 3.1 and I believe the software was DOS-based.
Can anyone tell me what software I can use that's compatible with Windows XP and what type of connection do I need to my PC? I have a 20-047 connector that I use with my Pro-528, will that work for the Pro 2035?
Thanks in advance for your help.
djeplett
NE Wisconsin
I had one of those scanners once. I never had the OS535 card in it, but I believe it requires a serial to serial cable. There is this software that costs $59.95:
http://www.datafileinc.com/index.htm#Home
But it looks like you might have some trouble unless you use Windows 3.1...
The 20-047 cable is for newer scanners and radios with an 1/8" phone jack for programming. I don't think it will work with your OS535 card, but I could very well be wrong.
I just found that Scancat can program your scanner and I believe it is Windows 2000/XP based. Check them out here:
http://www.scancat.com/
Cool thing is you can download demos from there and try them out to see if they work...
