usnasa said:
but i want to be able to use both at the same time can you tell me what to buy do they have them in radio shack i have a bnc connector ? how would i connect that
I run three scanners on one antenna. Here is how I did it. (I'll list what YOU need to accomplish the same thing)
Go to RS. Buy a CATV two way splitter, a handful of F connectors, two solderless BNC connectors, and a length of RG-58 or 59 cable. Oh, and a F connector crimper. (Pliers work, but not as well)
Go home, and cut the BNC connector off of your antenna lead in. If possible, cut it off so you have a foot or so of cable left with the BNC connector still attached. Strip the insulation off of both the BNC cable piece, and the antenna lead in. Attatch an F connector to BOTH the lead in, and the BNC piece.
Next, take the length of cable you bought, cut off about 2 feet, and strip both ends. Attatch an F connector to one end, and a solderless BNC connector to the other end.
next, screw the F connector from the antenna lead in into the input of the CATV splitter. Then, attatch each of the othe pigtails you made to the CATV splitter output via the F connectors, then connect the BNC's to your scanners.
That is it!
I use exactly this set up, only I use a three way CATV splitter. Works perfectly.
