Pro 2053 300 channel
BASSNUT
Duarte Ca
Can anyone please tell me if there is a backlight on the pro-2053 Scanner I have read this manual from page to page and I see nothing about a backlight
thanks for any info.
trentbob
W3BUX- Bucks County, PA
I had one a long time ago and if I remember correctly if you push the lock light button that display will come on for 5 seconds or you can hold the lock light button and you'll hear a beep and the display should stay on. I think it was function 7 that you could adjust the contrast. Just working by memory here. It was a great GRE made radio. They do get old and often don't work as well as they did when they were new.
I guess I should look it up and make sure I'm right but I think I'm remembering correctly.
BASSNUT
Duarte Ca
I already know how to do the contrast it's function and the number 9 what I need to know is there a backlight on this thing All the ones I've seen they're all green but I can't find anything and the manual about a light
BASSNUT
Duarte Ca
Yeah I already have that but the problem is it shows nothing on my scanner for a wrench or a light All the keys nothing mine is the 2053 pro 300 channel dual trunking
dave3825
Suffolk County NY
Are we sure that unit has a backlight?
Marks scanners Pro-93/2053/95 says
Marks scanners shows one pic of keypad and its for the Pro 93 and has a button with a wrench & light bulb.
The Pro 2053 does not appear to have those same buttons with a wrench & light bulb.
The manual for the Pro 2053 does not list "Backlight" within.
I kind of remember those scanners having an orange backlight that was just always on. The 93 and 95 have the on off feature to help preserve battery life.
BASSNUT
Duarte Ca
Nope there is no backlight on this unit so without a light it's useless to me in the dark, no big thing I just wanted to play around with it probably give it to my friend or just sell it for a couple of bucks
Thanks for the help
dave3825
Suffolk County NY
There is more than likely a thread or two out there on replacing the light. I know there is on for the 2052 model. A unit that old should be pretty easy to replace the bulb.
iMONITOR
Silent Key
S.E. Michigan
I clearly remember when I owned a PRO-2053. They had a green backlight as shown below.
images
trentbob
I do remember the 53 had a backlight as shown in the video above. I had all of those models and that's why I referred to the key lock, that's a key not a wrench and the light button.
Apparently the light went on on its own when you turned it on and in this case the original poster has a radio with the light burned out.
fxdscon
¯\_(ツ)_/¯
This is the ad from the 2002 Radio Shack catalog:
  • Like
Reactions: wtp
BASSNUT
Duarte Ca
Yeah that just indicates the LED display I was talking about a light that I can see in the dark but unfortunately this one doesn't have one so basically it's kind of useless for me in the dark lol I just give it to my friend or just suffer for a couple bucks I just want to play with it
trentbob
One thing I remember clearly after purchasing a number of these radios.
Digital, Motorola type ll smart Zone systems were spreading quickly from 2000 on. There were no digital scanners. Our mayor in my city GAVE my newspaper Motorola RX only radios in 2000.
After a lot of people spent a lot on radios like the pro 2053... GRE introduced the pro 96 in 2003 for Radio Shack. Changed everything.
Mo' money.
fxdscon
¯\_(ツ)_/¯
The ad lists it as a backlit LCD display
