PRO-2096 blank display...fixed!
brian
DB Administrator
South Carolina
I know that blank displays on the PRO-2096 are a common complaint about the radio. My model went back for warranty repair after 1 year because of the black lines across the display. Now, just over 1 year later, I powered up the radio after a few days with it off and the display was completely blank. The light was on, the panel buttons worked fine, reception was fine, but no display.
I decided since it was out of warranty I'd crack it open just to see if I could see anything before sending it back for repair. I decided to disassemble the front display panel, which requires desoldering a ground strap between the display panel and the system board, disconnecting a ribbon cable and several other multi-pin connectors and removing four screws. I then removed the display and button panel PCB board from the display panel, which required desoldering another ground wire, removing four screws and separating a multipin socket.
Once that was done, the display just about fell out of the panel - it's loose under the PCB board. It's connected via a very small ribbon cable. I delicately removed and reseated that ribbon cable. I then reassembled the display panel, reconnected it to the scanner, and the display worked like a champ.
Do this procedure at your own risk and your milage may very, but I was pleased that I was able to fix this problem myself. I suspect that when my display was repaired a year ago, that ribbon cable was not reseated securely and it finally disconnected. The soldering required is pretty simple.
I hope this is helpful to some with this same problem.
KT4HX
Spotsylvania County, Va
Unfortunately, the blank display seems to crop up not only in the 2096, but the 2055 and 97 as well. I personally fixed a 97 by re-seating the display ribbon cable, which is the usual fix. I think many on here have also done their own repairs, and unfortunately in some cases, some have had to do it more than once to the same scanner. To my knowledge, the problem was never truly addressed in any permanent fashion by Radio Shack while those scanners were in production.
bethanyv
Brian- Thank you for the post. I reseated the small ribbon, and the display is working perfectly!
Bethany
brian
DB Administrator
South Carolina
That's great, Bethany. Glad the information was helpful to someone. Clearly it doesn't work in all cases. Mine has worked like a champ ever since.
