Hi there. Just got ahold of a used Realistic Pro-26 (90s model) that has a buzzing sound out of the speaker and earphone jack when scanning/searching. Im pretty sure there might be a bad filter cap in this and would like to get it fixed. However i cant seem to open it...
Ive read the service manual and it states that to remove the front and rear case just unscrew the 4 screws on the back. Ive done this but i cant seem to get it separated. It also states that to remove the top plate unscrew the spanner nut around the BNC connector. Is this necessary to get it separated as it requires a tool which i dont have.
I also noticed that the earphone jack only has audio coming out of the right channel. Is this intentional or is it a fault?
John
John
