Pro-433
Nate1n22
Muskegon, Michigan
I have a Radio Shack Pro 433 that I have scan channels and obviously when someone talks it stops, but when it stops it will always cut out when someone is speaking.
I do have the delay on, but I'm guessing there is nothing that can be done to fix this.
mancow
N.E. Kansas
Does the audio cut out for a bit then come back?
If so you likely have the priority on which is checking another channel briefly.
Nate1n22
Muskegon, Michigan
Yeah, after it cuts the dispatcher off it will return to the channel.
If I set the priority on the frequency will it prevent this?
