pro-83
KE5BCP
Analog Man
Lewisville, Texas
anesti said:
can anyone tell me how to reset it?thx in advance.
Page 54 of the pdf manual:
"Resetting the Scanner
If the scanner’s display locks up or stops operating
properly, you might need to reset the scanner.
Caution: This procedure clears all the information
you have stored in the scanner. Before you reset the
scanner, try turning it off and on to see if it begins
working properly. Reset the scanner only when you
are sure it is not working properly.
1 Make sure your scanner is turned off.
2 While holding down 2, 9, and HOLD, turn on the
scanner. After about 3 seconds, the scanner
initializes and CLEAr appears.
