Friends,
I have used RR Search as best I could to find this info but came up empty.
In Colorado, using a Pro-96 on the State's Motolorola APCO 25 system.
Looking at a control channel in Manual. The scanner displays the channel number, the channel mode, the frequency and the text I've applied for the site. No problems with that stuff.
But the bottom line I haven't found an explanation for.
When receiving a control channel signal It looks like
'96:SYD1C 90%' where SYD1C cycles to T0105 then BEE02 then back to SYD1C. The
% number moves around a bit though not in a pattern I can recognize.
I *think* that SYD1C is the system name and T0105 is the particular tower within the system.
What is the BEE02 field? What parameter is being presented in the % field?
Is this stuff system-specific or is it Pro-96 + APCO25 standard stuff?
Thanks for your help!
