Is there any way to make the backlight stay on and not shut off on the pro-96?
C ctpd845 Member Joined Dec 28, 2005 Messages 425 Location Martin, Ohio Jun 1, 2006 #1 Is there any way to make the backlight stay on and not shut off on the pro-96?
STiMULi Member Joined Nov 14, 2004 Messages 1,566 Location Tucson, Arizona Jun 1, 2006 #2 Press and hold it for a few seconds. It will beep and the backlight will stay on.
Dubbin Member Feed Provider Joined Dec 19, 2002 Messages 4,462 Location Findlay Ohio Jun 1, 2006 #3 Press the light button until it beeps. It will stay on until you shut the radio off. I type to slow
JESSERABBIT Member Joined Jul 26, 2005 Messages 903 Location Charles Town, Jefferson Co, WV Jun 1, 2006 #4 Try holding the "light" button on until it beeps. I hope this helps.
C ctpd845 Member Joined Dec 28, 2005 Messages 425 Location Martin, Ohio Jun 1, 2006 #5 Thanks for the quick help. It is much appreciated.
STiMULi Member Joined Nov 14, 2004 Messages 1,566 Location Tucson, Arizona Jun 1, 2006 #6 Ha Ha I won
Dubbin Member Feed Provider Joined Dec 19, 2002 Messages 4,462 Location Findlay Ohio Jun 2, 2006 #7 STiMULi said: Ha Ha I won Click to expand... Yes but now you are in the crosshairs of two more people
drouse3 Member Joined Dec 22, 2004 Messages 122 Location Santa Clara, CA Jun 2, 2006 #8 My pro-96 does not beep when I turn the back light on. Did I turn it off with win96 or is it just a problem with my scanner.
P pfish Member Premium Subscriber Joined Dec 2, 2004 Messages 545 Jun 2, 2006 #9 It won't beep if you have the keypad beep disabled. Or if you don't hold it long enough...you have to press it for at least a few seconds to make it stay on.
FIRE321FIGHTER1985 Member Joined Dec 19, 2000 Messages 606 Location Winnsboro, La Jun 2, 2006 #10 To disable the light, you turn off the unit or press the light button. Mark
drouse3 Member Joined Dec 22, 2004 Messages 122 Location Santa Clara, CA Jun 2, 2006 #11 The key pad is on, the backlight will stay on, Just no beep after two seconds.
