PRO-96 DSP Firmware
BuiltonAsus
I was just checking to see what DSP firmware is popular with everyone here, especially around the D-town area. I have just recently upgraded to DSP 1.4 and have noticed considerable problems decoding digital. Just checking to see if v1.4 also has caused this problem with others in the surrounding area. I will probablly revert back to the orginal firmware version.
rdale
Lansing, MI
DSP 1.4 is the best for Detroit, if you don't monitor simulcast systems like them or Genesee or Monroe or Lucas then you can go to an earlier version.
kc8zdf
Michigan
Like are rdale said I don't listen to the d-town or gen county so I use the 1.2 for my county which is apco 25 and It does its little digital thing every now and then but works better then 1.4 did for me here.
w8jjr
Lincoln MI
1.4 here. It really made a BIG difference in the recepection of Detroit and Macomb.
Jimmy252
Oakland County, MI
i listen from farmington and the 1.4 didnt help me with detroit, neither did the 800 MHZ Duckie, i guess im just in a bad location for gettting a detroit signal.
kb8rvp
Michigan
I tried 1.4 for a while and went back to DSP 1.2 for the best results. DPS 1.4 went digital to much. Mike
