swat said:
((((((AM/FM mode so you can tune your favorite radio stations, too)))))))) This is from the RadioShack web page
MY question is how do you get your favorite radio station if someone can help that would be great... and by the way the radio stations here in sacramento are 102.5 103.5 98.5 106.5 and much more please help
I looked at the website after your post. I also found out that the PRO 2054 has "AM/FM mode for listening to your favorite stations" as well. This is listed in NEAT STUFF under the FEATURES section of the 2054. It also lists the "Frequency coverage: 28-54, 108-136.9916, 137-174, 406-512, 800-960MHz (except for cellular)" under the same exciting points. I am taking a wild guess that since normal AM FM stations are not in the coverage zone for this scanner, you need the additional equipment, the [insert cheap am/fm model number] radio to pull in your favorite stations. Equipment sold separately, I might add, along with the RS batteries.
If you look a little harder, you will notice that the PRO 2096 has a "Function key to access special modes and programming options". This is also listed in the NEAT STUFF section under FEATURES for the 2096. Just think of what scanning could be like if all scanners had this cool function key! If RS doesn't watch out, every other scanner manufacturer out there will be copying their idea of a "function key".
Tony
