Pro 97 & EDACS
williams63
Mississauga , Canada
My city uses EDACS....
Now the edca's system must be entered in the Pro97 lowest to highest.
Recently, the ciity changed control channels...
My question is :
The way my 97 was done was this way and it worked fine :
Lowest was the cc.
Now the 2nd freqency is the control channel...
Do I now leave in the 2nd frq which is LCN # 2 or do I program that LCN #2 to channel 01 of the Pro 97. ?
W4KRR
Coconut Creek
The frequencies need to be entered in their correct LCN order, starting with channel xx1. The order of the frequencies will remain the same even if the control channel changes. Sounds like you're saying that the scanner was working before, but since the control channel changed, it isn't working anymore? If that's the case, sounds like you're missing frequencies or a control channel.
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Is Sudbury Ontario your City? If so, is this is the correct LCN with the CC in slot 02?
01 866.03750
02 866.28750*
03 866.77500
04 867.27500
05 867.78750
06 868.05000
07 868.36250
08 868.46250
09 868.68750
10 868.88750
11 868.95000
