Pro 97 Preprogrammed Frequencies
csuh13
SF Bay Area
Hello all,
Does anyone know of a process to restore the preprogrammed 150 some frequencies into the Pro-97 once you delete them?
Usually I just clone it over from an unmolested Pro-97, but I thought they might be contained (hidden somewhere) in the firmware (a la Pro-96) and could be restored via a secret keypad command...
I'd swear that I've seen instructions online on how to do it, but now I just can't find them...
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Initializing the scanner may work. Turn scanner on and when Multi-system Trunking Scanner appears: Press 0, 1, ENT consecutively.
Woodstock
Initializing the scanner deletes everything. Go to one of the yahoo groups for the Pro-97 and download the P97 file that has all the original frequencies/settings.
on my pro 97 the addon sheet with a list of freqds says just hit 3 when multitrunking appears
anywho I will upload the p97 file now rename the ext p97
RayK
Bradenton,fl
Hi, the Pro-97 comes with 155 preprogramed frequencies in the ROM ,they will load into channels 000 to 154.
1)Turn off scanner and then turn it on again.
2)When the Multi-system Trunking Scanner appears, press PGM.
3)Press 1
This was on the addendum included with the scanner.
Ray
csuh13
SF Bay Area
3)Press 1
Ray
Perfect... Thanks!
Eng74
Kern County, CA
csuh13 said:
Hello all,
I would never let any of my scanners get molested, it is just not right
DaveIN
Founders Curmudgen
West Michigan
3)Press 1
Ray
Thanks, I've added that to the PRO-97/2055 Wiki.
RayK
Bradenton,fl
Hi,attached is the Pro 97 Addendum ,sorry the quality is't good ,but I was limited by what
I could upload,enjoy .
Ray
  • PRO-97 Addendum.pdf
jerzymaniac
eht
pro96 digital scanner
question just purchased it from radio shack, my town has provoice and anlog trunking. willthis pick it up, been trying to program the trunking no luck.
help please
fmon
Eclipse, Virginia
Hey jerzy, welcome to the forum. Yes, the analog ID's can be heard. Help us help you...What system (city, county) are you programming?
MIKELESP
3)Press 1
Ray
This was the fix I was looking for. I never got the addendum. Thanks a lot.
gmclam
Fair Oaks, CA
Corrected addendum
Here is the corrected addendum....
  • 20-527 addendum_corrected.pdf
lugoffman
Spring Hill, Florida
csuh13 said:
Hello all,
i just bought a new pro 97 i got all of them if you want them still
