Pro 97 Programming with Win 97
ranger821
Fort Walton Beach, Florida
Ok. Got my Pro 97 programmed WITH the Win 97 software. It put the frequencies into the scanner, but seems to be in a wierd place. Banks 0 seems to be like it's supposed to be. Bank 1 was put in on Channel 134 up and bank 2 starts at 255. I did not delete the frequencies that were in rhe scanner before I reprogrammed it. Works fine, but I have only listened for a little bit of time and I did not use an outside antenna. Will look at that today. I have a diamond dual bander 2 meter/70 centimeter up about 30 feet that I use for amatuer radio.
Northe
Green Valley, AZ
Ranger,
Did you download the frequencies that were already in the scanner to Win97 before you inputted the new frequencies? I'm not exactly sure what would happen if you didn't.
You could go ahead and do it now. Then, if you want, you can move the frequencies you entered to the top of the bank, save the Win97 file, and then upload to the scanner.
Northe
N6KO
ranger821
pro 97
The ones that were in the scanner was from one county. Okaloosa. When I uploaded the frequecies that I put in the software, it wiped out the ones that were in the the zero bank. Not to worry as the ones I put back in were the same with quite a few additions. Like you said I could go into the software, move the frequencies into channel 1 thru ? in each bank and upload it again. The scanner in working fine, just can't figure out why the channels went in that way. I am using the free version of Win 97 so I want to get it like I want it before the 30 days is up.
John
gmclam
Fair Oaks, CA
Software like WIN97 will overwrite all frequencies in the scanner. If you want to preserve what is in the scanner you need to download from the scanner, edit to add or change to what you want, and upload everything back to the scanner.
What you state does NOT sound correct. If a frequency is displayed in WIN97 as channel 000, that's where it should be programmed in the scanner. The uploading to the scanner overwrites everything, so it does not matter what may or may not have been in there before your upload.
The "free" version is the same as the paid version. If you intend on using this scanner for any time, having software and a cable is pretty much essential. Certainly you can learn to program your scanner by hand (recommended), but it takes a lot of time to enter stuff, especially alpha tags.
So that it makes sense to you, use the bank editor in WIN97 to erase the frequencies of the banks you are not using. Put everything where you want it to be. If after you upload it to the scanner, you do not get what you expect, perhaps you should post your p97 file here so we can look at it. If the file is correct, it indicates a problem with the scanner.
ranger821
Thanks. I will move them today to the right spot. Yes, I agree about doing it manually. It's a pain, but I have the programming steps to each of my scanners on a quick reference card. Makes it easier. Pretty place where you live. I lived in Citrus Heights for about 3 years just before I retired from the AF and moved to Florida.
John
gmclam
Fair Oaks, CA
Thanks. There are better and there are worse. My main focus was/is a high location with good radio reception. For example, go across the river to Rancho Cordova and you're abou 300 feet lower. Now that Citrus Heights is a city, it does nothing for me. Good luck.
