pro 97 software?
cristisphoto
Ther are Numerous
Starrsoft???!!??
Butel
Scancat
and GREAmerica sells the cables
Crista
RayK
Bradenton,fl
Being most of us are not mind readers , and it seems your using a Pro-97 scanner , what interface cable are you using ,what software are you using and what computer system are you using (windows 98 ,xp ??)
DM4
WOOD RIVER
RS 20-047 cable Win 97 software,win Xp pro.it keeps saying waiting for hedder,then it says timed out loading header!
Don_Burke
Southeastern Virginia
Do the lights in the amber box on the data cable light up? If not, get into Win 97, click on "configuration" and figure out which port you need to be on.
gmclam
Fair Oaks, CA
USB cable is COM port converter
Go to control panel > system > hardware > device manager > ports ... and see what COM# port has been assigned to the cable. Put that port # into the software and try again.
RayK
Bradenton,fl
Please note on the cd with the rs usb cable is a manual on how to unstall and use the cable,
step by step instructions and troubleshooting in pdf format
