pro97 low band
jakegday
Banned
hello, i see you can get a pro 97 for $80 at overstockdealz and i am seriously considering this purchase, i was just wondering if anyone can comment on how it performs on the low band, here in nebraska the state patrol uses the 42 mhz range, and i can NEVER hear anything with my pro 76, my pro 83, or my cobra sr900, i even purchased the radio shack telescopic antenna, it made a huge difference in both vhf hi and uhf but not a bit of difference on the low band,
so, anyone??
scanjunkie
Montgomery County, PA
It all depends on the signal strength when it comes to low band. But I have always had great success with ALL bands on the 97!! But then again, the low band signals in my area are strong!
see the general scanning forum someone has has already received one & reports it as like new.. GOOD DEAL!!
gmclam
Fair Oaks, CA
The CHP is also on low band I use my '97 when mobile to pick them up. The real key though is a good antenna - one designed for low band. This is especially true in a vehicle. Don't expect the stock rubber antenna inside a vehicle to do all that great. Put a low band antenna outside and you'll be good to go.
jakegday
Banned
yeah, i did, and didnt see any feedback on the low bands performance
can you suggest a good low band antenna then? what do you use?
BaLa
4GRC+83; Temple, TX 76502
I used to have a Pro-97
I have a 5/8 Wave VHF Antenna, on an NMO Trunklip mount and it worked great.
oh...was monitoring the MSHP (42mhz range also).
jakegday
Banned
ok, i want the right antenna set up, but i dont know where to start, what do you recommened? could you perhaps give me a link to a good one?
jakegday
Banned
lol, that figures, the thread ALWAYS goes dead once i start asking for good antenna suggestions
gmclam
Fair Oaks, CA
You should post that question in the ANTENNA forum!
N1BHH
Jackson Square, East Weymouth, MA.
Your best bet is any antenna up fairly high, on your roof or on your air conditioner or I could go on forever with or's. Any decent scanner antenna will do as long as it specs out to work on 30-50. Just a telescoping antenna won't do unless you are close to a station transmitting. Outside and high is best, just get it outside.
illini52
You'll be amazed how well a proper antenna works for receiving lowband. For 42 MHz, an antenna about 67" will work well.
Viper43
Or get the radio shack discone which works for all ranges. I used to pick up a lot of low band skip with it too. And it covers everything else as well :)
V
