Problem
fireguy810
Hello All,
I have a problem that I hope someone can help me with.
I recently set up a live scanner broadcast feed using a BC350C scanner, scanning low-band, high band VHF, and UHF freqs. No problems
I just switched to a BC780XLT scanner for the feed, scanning the same frequencies. The only different thing is that PL is now being used.
My problem is that since I have hooked up the BC780 I have a constant static hum on my feed. I dont hear it over the speaker on the scanner, but I've connected to the feed on two different computers and the same static hum appears.
When I switch back to the BC350, theres no hum.
Anyone have any ideas?
Lexxx
Kitchener, Canada
fireguy
Are you using the same audio cable between the two radios and the computer, or have you bought a second cable? To isolate the problem I'd suggest changing as little as possible to start with.
A mono cable rather than a stereo cable might solve the problem too. You don't have to buy an entirely new cable, just a stereo to mono adapter at one end should work. Unless you are doing some fancy left - right speaker streaming you shouldn't need stereo anyway.
If none of that works try grounding the 780xlt. Run a wire from some screw on the radio to a screw on the computer. The computer case (desktop type) should have at least 4 screws at the back holding on the computer outer shell. I'm assuming you have a desktop with a grounding three pronged plug, and not a two pronged laptop power supply.
Good luck,
Lexx
www.ykf.ca
fireguy810
I'm using the same exact cable. It is setup as stereo, I suppose I could try mono, but I didnt have this problem when I hook up the BC350.
w2lie
New York DB Admin
Long Island, NY
I can tell you from experience, Lexxx is right, use a mono connector at both ends. That completely eliminated my hum problems.
In fact, I always make my own audio cables, because if the connection is bad, I can always beat myself up!
Uplink
Los Angeles County
This is a common problem due to the different ground potentials of your scanner and computers sound card. I use the PAC SNI-1 FILTER on my feed, works great! Just use an 1/8" mini to RCA adapter and RCA Y cables. You can get the filter for $10 Ebay, as well as Crutchfield here
iMONITOR
Silent Key
S.E. Michigan
Hook up a ground wire from the back of the metal chassis of the scanner, to the back of the metal chassis of your computer. Or, for a quick test, hook up an RS232 serial cable between the scanner, and the computer, which will accomplish the same thing.
Uplink
Los Angeles County
That was what I tried at first, in my case it didn't help. Filter works awsome and no DC can get through.
