Program Astro Saber Out of Band?
stevez97
Myrtle Beach, South Carolina
Can a 470-520 MHz Astro Saber be programmed to operate in the 460.XXX range? Would some type of HEX modifications be necessary? Would the 440 Mhz range be a stretch?
Thanks for any and all help?
rescue161
KE4FHH
Hubert, NC
The first four of the serial number are H04S. According to Batlabs (Astro Mobiles) the 4 indicates 470 - 520 mhz. So this might not be accurate?
The main site at Batlabs is way out of date. The correct splits for the Astro Saber what bezking stated.
There are two UHF splits and they are identified by the 4th character, i.e., "R" or "S". The R indicates 403-470 and the S indicates 450-520. There is no "Q" split Astro Saber.
Astro Spectras are another story.
bezking
On the Road
You have an S-split radio - 450-520 mHz, so your frequencies in the 460 range will work fine with no modification necessary.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Batlabs links the Astro Portable to the Astro Mobile model breakdown chart. That's why there's confusion over the bandsplit.
bezking
On the Road
In general, when you look at the first letter after the H in the model number, it usually means:
Q: 380-470
R: 403-470
S: 450-520
K: 136-174
U: 700/800 mHz
