BCD396XT/BCD996XT: Programming a BCD396XT
Koolbreeze
Madill, Oklahoma
I haven't been in the game for quite some time. I can't find FreeScan to reprogram my BCD 396XT. Can someone tell me what freeware may be available. I am a little rusty. My local Law enforcement have switched to digital, and I need to brush up on how to get this done. Any info is greatly appreciated.
tvengr
Well Known Member
Baltimore County, MD
It appears that there are no sites in Marshall County for the OKWIN trunked system. Oklahoma Wireless Interoperability Network (OKWIN) (P25) Trunking System, Various, Oklahoma Madill is well within range of the site in Johnston County:
1 (1)035 (23)TishomingoJohnston856.9375857.9375858.9375859.9375c860.9375c
Marshall County
Kingston and Madill Police are on the Marshall County Sheriff's talkgroup​
DEC HEX Mode Alpha TagDescriptionTag
549225DMarshall Co SOSheriff DispatchLaw Dispatch
There are also conventional frequencies: Marshall County, Oklahoma (OK) Scanner Frequencies and Radio Frequency Reference
Koolbreeze
Madill, Oklahoma
Marshall County​
DECHEXModeAlpha TagDescriptionTag
So let me ask you this. This talk group is something I can't hear on my scanner? I am using ProScan now. Thanks for your help!
tvengr
Well Known Member
If programmed correctly, you should be able to hear the talkgroup. The D in the Mode column shows it is P25 Phase 1 and not encrypted.
Koolbreeze
Madill, Oklahoma
I must be doing something wrong. I pulled it from Radio Reference and imported to scanner, but I don't see the scanner reading it.
Ronaldski
MI DB Admin
Bay City MI
You also need to include frequencies of course. Stated your county doesn't have a tower, so what you would need to do is include the tower frequencies from your neighboring counties. All you need are the control frequencies that are in red in the database , minus the letter c.
Add in each county as a new site within your county setup in proscan. Then assign each site the SAME quickkey #.
Koolbreeze
Madill, Oklahoma
Thank you. I will give that a try!
tvengr
Well Known Member
If you continue to have problems, please attach your ProScan or FreeSCAN programming file so that we can take a look at it. Here is a PDF file which will answer all of your questions about using quick keys:
  • Uniden Scanner Quick Key Instructions DMA.pdf
LukeHam_187
Did you ever have luck getting Madill PD now that they are on a digital system? I live in Madill too and have tried the Johnston County site and frequencies and still can’t hear them on the talk group for Marshall county. Any help would be appreciated. Thanks
