Programming a Remote Mount CDM 1250
fdnyradio
Staten Island, NY
I currently have 3 Remote Mount CDM1250 radios. I have been hearing conflicting reports as to how to properly program these radios. When assembled in a non remote config they program just fine throught the mic port with no errors. In the remote config the mic jack does not seem to be working as the CPS cant read the radio. I understand there is a way to program these radios through the rear 20 Pin connector. How can i go about doing this and what will i need. Thanks
fineshot1
NJ USA (Republic of NJ)
I have not encountered this problem with the 2 or 3 remote mounts
that i have programed over the last few years but i have heard others
complain of this problem. When i programed these remote mount
CDM1250 radios i programed them via the head mic conn and had
no problem. see the info below from the batlabs web site.
hope that helps
http://batlabs.com/images/cdmprog.gif
or
http://batlabs.com/images/rkn4083.gif
Leave out the P1 conn to the test set - not needed.
below is the pinout on the acc conn
http://batlabs.com/images/cdmacc.gif
Jake10021
I have programmed many remote head CDMs and have never had a problem using the following procedure: Turn the radio on, disconnect the remote head from the radio, plug your programming cable directly into the front of the radio (not the head), when you are done reconnect the remote head.
I am looking for a remote mount kit for cdm1550......aside from ebay, anyone know were i can get one at a decent price
