Ce-86 vista prolific usb to serial com cure all
Okay so I purchased the CE-86 software for my Vertex VX-351, I am a FF/EMT and use it on the two departments I work on. After purchasing the software it wouldn't work on any of my laptops *2 running vista, 1 running windows 7. SO i tried it on my PC with XP SP2, I kept getting a cable issues. Finally at work one day I messed with the program on my VISTA laptop for 4 hours. This should fix your VISTA issues. The USB to serial com is not compatible with VISTA and the drivers they give you don't work so, I did a hardcore search and found these. VISTA will also only work with CE-86 version 2.0 & above, for a link to that software you will have to send me a message.
drivers:
http://www.cooldrives.com/lib/cooldrives/vista-prolific-chip-driver-for-serial-adapters.zip
before you install this do these actions:
Unplug your Prolific USB to Serial Com cable
Open up Computer
On the top left in the search bar type in "Prolific"
Select and Delete everything that says Prolific or PL 2303
After that is completed do these steps:
Right-Click on Computer
Click on Properties
Click on Device Manager
Click in Com Ports (Com & LPT1) depending on what model you have
If you see the Prolific USB to Serial Com Cable right click and uninstall it
After this has completed reboot your computer.
Now install the VISTA drivers shown above,
plug in your cable
go back into the device manager and it should now be installed just fine.
Right Click on Prolific USB to Serial Com unless it already says Com 1
Click Properties
Click the Second Tab *I forgot the name at this moment and time*
Click Advanced
Now change the Com Port to Com 1
Click Ok
Close out of all that
Next open your CE-86 Software
Plug in your radio but leave it off
Click on New
Click On File
Click Configure
Change it to Com1 *it defaults at come one so you shouldn't have to change it, if the COM PORT is blank you didn't click on NEW
Click on Upload either under Radio or just the little button, when prompted turn your radio on. you should be full functioning...I hope this solves everyone's problems.
