Good Morning, I would appreciate it if one of our members could give me the technical description of the programing cables for the SD100 & SDS200 Scanners.
Thank you, Dave
Thank you, Dave
Hi! Really need the particular cables easier to use especially when away from home, than trying to deal with the micro sd card.The easiest way I have found is to just use a Micro SD card reader and program the Micro SD card then insert it.
Also see this post from before.....
Programming cable for SDS100 & SDS200? | RadioReference.com Forums
Just a standard micro USB data cable. Nothing special about them.Hi! Really need the particular cables easier to use especially when away from home, than trying to deal with the micro sd card.
Its just a micro USB cable, there is really no best, as long as it isn't "power only" but anything off amazon should work.
“But anything off Amazon should work”… NOT TRUE. I ordered 2 of the right angle plug cables recommended by someone who said they worked for programming. They don’t. Change that last line to read “Most anything”.Its just a micro USB cable, there is really no best, as long as it isn't "power only" but anything off amazon should work.
Oddly, I have problems with the right angle cables too.“But anything off Amazon should work”… NOT TRUE. I ordered 2 of the right angle plug cables recommended by someone who said they worked for programming. They don’t. Change that last line to read “Most anything”.
In the case of both right angle cables I bought and didn't work, they were advertised as data cables.For mini USB there are 2 types of cables. Data cables (data and charging) and charging only cables Many years ago phones charged much slower and the charging only cables would use the data pin to provide additional charging capabilities. So some mini USB cables were designed for charging only while others were data and charging. Its possible these right angle ones you got were charging cables only.
What problems do you have? The post that one recommended one to me said it would work for programming the SDS200. It doesn’t do that and since it’s not looking to recharge the battery like the SDS100, the cables are useless, well almost useless… I use them as dust covers!Oddly, I have problems with the right angle cables too.
No data connection on the S100. I attempted to use the right angle cables on that to alleviate strain on the connector.What problems do you have? The post that one recommended one to me said it would work for programming the SDS200. It doesn’t do that and since it’s not looking to recharge the battery like the SDS100, the cables are useless, well almost useless… I use them as dust covers!
Ok. Thanks. But once burned so I need to ask… can you use the cable to program the SDS200? (I obviously don’t need it to charge any battery… it’s not the SDS100.These are the right angle micro USB cables I use for 2 of my SDS200 scanners, and other devices. I'm currently using 9 of them with no problems.
-Ok. Thanks. But once burned so I need to ask… can you use the cable to program the SDS200? (I obviously don’t need it to charge any battery… it’s not the SDS100.
