programming error Harris P7100
penthousedude
Was: OakvilleCub
Halton
hello, I am trying to program a harris portable, and get a message that radio not acknowleging check connection etc. I can read a profile in the radio, but not system, ids, freqs etc. I hold down the
3 buttons when i turn it on and I get all black bars. I am using a ribless cable direct to my serial port com port.
I made sure I have the proper port, model number 800 system, etc,
any thoughts?
cheers
Forts
Ontario, Canada
That doesn't make sense... you say you can read the profile but not the info? The info is in the profile. What version of ProGrammer/RPM are you using? Real serial port or USB-Serial adapter? I've found some of my radios are very fussy about what PC I use and what type of serial connection.
penthousedude
Was: OakvilleCub
Halton
programming error
ok,
here we go:
I can read the information from the radio using the "data extractor", but when i try and read the radio I get
"could not intialize radio, make sure radio is in programming mode and the programming box or cable is
connected to the correct port"
I have held down all three buttons when I turned it on and I do get rows of solid black squares so I
believe I am in the programming mode.
I am using the standard serial connection, no rib box needed.
kb4cvn
Silent Key
Nowhere near a paved road, away from the maddening
Personality Lock
Secured Personality file, requires Personality Lock, a Cryptocard (smart card) with the correct 256 bit key.
If you go look at the Personality Data Tree, you will see little yellow padlocks on the secured radio systems in the personality.
See image below:
penthousedude
Was: OakvilleCub
Halton
no. i was given the radio and software. i purchased the cable on line. i am yse to motorola stuff. thx
penthousedude
Was: OakvilleCub
Halton
p7100 programming
hey there,
I have version R10B07 (10.2.1.7 )
i was looking how to get into the tree as suggested above, but I don't even see that under view in the
menu bar.
cheers
ElroyJetson
I AM NOT YOUR TECH SUPPPORT.
DO NOT ASK ME FOR HELP PROGRAMMING YOUR RADIO. NO.
I'd imagine that this little glitch was fixed years ago, but once upon a time, if personality lock was enabled, older versions of RPM could still save the file and allow some readability of it IF you made ANY edit to an editable field. Simply changing the name of a single channel, system, or talkgroup then allowed the file to be saved.
When I discovered this I laughed for a while.
It didn't give me full access to all the data in the personality but at least I could save it.
I suspect that glitch was fixed long ago.
penthousedude
Was: OakvilleCub
Halton
i have tried both ways, without holding buttons I do immediately get the "program" word in the radio window
but i still get the error "could not inialize radio"
