Programming 'favorites' (scanlist 21) in ARC500 for Pro-106
#1
Can anyone tell me how to populate scanlist 21 (favorites) in teh ARC500 software? You cannot download into it directly and I cannot see any way to move objects into it either.
#3
programming in favorites
Thanks. Setting 'on' in the favorites column worked. Was this documented somewhere that I missed? I searched the ARC500 manual for 'favorites' and found nothing. It would be nice if the software allowed movement into favorites or direct loading into favorites. That would be clearer. You can see 'favorites' in the scan list preview but I could not find any way to populate it!
Franktown, CO
#5
Apart from the fact that you can't set alpha tags for the "Favorites" and "Skywarn" scan lists, there's no reason for PC software to handle those two any differently from scan lists 1-20.
