SDS100/SDS200: Programming p25 digital
Squonk917
Yonkers,NY
I’m trying to program westchester county police on my sds100 manually but doesn’t seem to pick up any signal. Does it have to be programmed via computer? I know it went to digital and the frenquency is the same but the tone is now 154 NAC. Do I need a TGID number?
lkas
Cheektowaga NY
It is much easier just using the sentinel software. You can program it manually. You will need the TGID unless you set it to "search"
bemyax
Waterloo, Iowa
The SDS100 can stop on talk groups that are not programmed when in ID Search mode, versus ID Scan mode.
Pressing the System soft key will hold on the system. Press the Function button, then E/Yes to toggle between search and scan.
lkas
Cheektowaga NY
what about this? try putting in the TGID as 1
Westchester County
Law Enforcement
FrequencyLicenseTypeToneAlpha TagDescriptionModeTag
155.31000WPEM283RM154 NACWCPD Ch 1/2County Police Ch 1/2P25Law Dispatch
155.55000WPEM284RM192.8 PLWCPD Ch 3County Police Ch 3FMNLaw Tac
151.38500WPRH588RM223 DPLWC CorrectnsCounty CorrectionsFMNCorrections
RMason
Mississippi / Colorado
Westchester county police is shown in the database as a Conventional P25 frequency. As mc48 described, this is programmed as a conventional channel with digital audio type. This is not a trunked system - and there are no TGIDs.
lkas
Cheektowaga NY
fyi.. u can program it as trunked and load it with TGID 1 which allows you to get radio ids and then tag them
Squonk917
Yonkers,NY
To everyone that replied to my post thank you so much with all of your input I was able to finally figure it out and set it up.😃😃😃😃😃
