programming pro-197
stawho
Wyoming,Mi.
bought a new 197 and the computer prbramming cord came with a free trial software. manually programed a handful of freqs in it.then when i took some time to plug it into the puter with the free software i could'nt see where i programed anything? am i expecting to much from the free software? also the scanner did'nt seem to be communicating with computer ? i have not tried loading anything into the scanner yet from the puter
mikey60
Oakland County Michigan
Two suggestions:
1. If you are using the short 3" adapter cable that comes with the RadioShack cable, remove that adapter and plug the Stereo connector into the scanner. The PRO-197 requires the stereo connector and will not work with the adapter.
2. Verify that you are using the correct COM port to connect to the scanner. The port can be determined by looking in the Ports profile in the device manager on your machine.
Mike
stawho
Wyoming,Mi.
thank you, i thought they wanted you to use the short adapter with the base/moble unit. one problem solved.
once i find the correct port ,, what do i do? click on it? to choose it. thanks again.
N8IAA
Fortunately, GA
Depends on your OS. If it is Windows7, windows will find it for you. But, you might have to go to the configuration menu in the software to enter the comport there. Make sure you download what you put into the scanner to the software, or you will lose what you programmed. Also, make sure that you have the latest drivers for the cable.
HTH,
Larry
stawho
Wyoming,Mi.
thank ya, i have windows xp . should'nt the software that came with the cable work or should i search the internet for something newer?
bama9999
Gulf Coast
Follow the link in Mikey60's signature above, and download PSREdit500 and give it a try. It's got a 30 day trial period so you can check it out fully. I use it to program my Pro-106, which is the handheld version of the Pro-197, and it works great!
mikey60
I'm sure it will work, but it may not automatically find the correct port. I'm not familiar enough with that program to know if it has a method of finding the port or not.
I know that WIN500 and PSREdit500 have direct access methods to access the cable, so you don't need to know the port. I don't know about any of the others.
Mike
stawho
Wyoming,Mi.
thank you. i will give it a try. when i get some more time to spend on it, hopefully by this weekend i can sit down and really spend some time with it
