programming software help
hiegtx
Dallas, TX
dps 1-20 rpt base a ,base b ,etc...not a word on these
Most likely, the main DPS channel that you might hear, would be RPT 13, which is the Aledo site, used by troopers in Parker County to talk to DPS-Mineral Wells dispatch.
If I create a PSREdit file for you, can you save it & load it?
txmab
burleson texas
Wife says no problem, my I.T. here ,believe i need one that would be great. does it add to what i have or erase all and dupe yours?
hiegtx
Dallas, TX
For the PSR-500 (and the related scanners, as I mentioned above in response to your "clone" question), the programming file always overwrites whatever is in the scanner. You cannot add/change or otherwise modify a file & only send that update to the radio. It's all or nothing.
Almost done with a file, then I'll email it.
I have:
Conventionals
Johnson County
Tarrant County
Hood County
Parker County
Ellis County
Medevacs (Careflite/ Air-Evac, etc)
Texas DPS
Trunked Systems:
Burleson
FW/Tarrant County
Mansfield
Arlington
Parker County
You can always delete or lockout anything that does not interest you, save the changes, and then load the modified file.
hiegtx
Dallas, TX
It worked perfectly!!! You've been a huge help! Thank You again !Txmab
You're welcome.
Although I did not add them, you should also be able to hear Dallas Fire-Rescue, and many of the Dallas PD channels, as well as Grand Prairie.
See if what's loaded now suits you, and if you want 'more' later, they can always be added.
