XTL/XTS5000 Programming troubles....
EngineCo8
KQ4CUD
Newinton, VA
So, I'm definitely trying my best to figure this out, and thought I was doing ok with it....but maybe not so much. So, as some of you may know I acquired an XTS5000 m1 VHF from the ebay and came up with a list of what I wanted programmed on to it. Took it to a radio shop and had it programmed (because at the time I thought the software was only available for a fee from Motorola). Took em about an hour....and cost more than I'd like to admit. Well, they finished it up, and I got it home and it worked with my simplex channels, but not any of the repeaters. After reviewing the PDF of the codeplug they programmed the in/outputs of the repeaters backwards (put the input to the radio rx and output to the radio tx). I contacted them and they said they could fix it, but it'd cost me because the they programmed it to what my list said. So I began doing more research and discovered that the Astro25 software was free for download (from the official Motorola website, I did have to call and have my account fixed and reestablished since it's been a few years since I downloaded CPS software). I downloaded the software, borrowed a cable from work (yes the guy in charge of our radio shop approved my borrowing it), and fixed the frequencies. And BAM it worked.....however.....when I pressed the PTT button, it emitted a long beep before it allowed transmission, I didn't particularly want that and originally thought that it was not connecting, so I began my research into the issue. I discovered on a thread here that it was a setting in the MDC tree on the CPS, turned it off and no more beep....but also no more tx to my repeaters. Simplex frequencies still works fine however. What did I do wrong? I have the original copy of the codeplug (that they put onto the radio to begin with) and before I mess with anything again, I feel I should seek guidance on what I need to do.
a417
Do the repeaters require MDC (or other signalling) for access? You need to find the input criteria, and make sure that it matches what you are sending out.
EngineCo8
KQ4CUD
Newinton, VA
I don't believe that they require an MDC setting...but I could be wrong. 🤷‍♂️
mbnv992
Also known as MT2000 man on Batlabs since 2001+
AZ
Contact the owner of said repeater and find out the exact programming parameters needed ( ie - TX / RX PL/DPL tones, etc etc ). Double and tripped check that, as well as that you have the correct offsets as well.
EngineCo8
KQ4CUD
Newinton, VA
I did send an email to them for further verification (after reading this). Waiting for a reply. Thank you for the suggestion.
