Programming XTL2500 for ham radio
fivetenzen
Northern
I have a xtl2500, correct cable and programming software- I can get into the radio, Thought It would be like other radio software I have used and with a little looking around be able to figure it out. But go into the radio and it had been wiped clean and everything is blank so nothing to go on. Not sure if it’s over my head or it overwhelMed me. I think if I had an example, and some pointers - it might be something I could figure out. Is it possible for someone to send me an example for a simplex freq. and a repeater input? If I’m asking to much or out of line, please just let me know. I’ve programmed lots of ham radios and scanners - had my amateur license since 95, I’ve installed Motorola radios, and everything else from A to Z as I have been a Mechanic for over 40 years. But never got into the programming of Motorola and interested in learning. This is my starting point. Thanks in advance for help and input. 73’s
wgbecks
NE Wisconsin
It sounds initially like you're saying you can't read the codeplug from your XTL2500 but then you follow-up and say it's wiped clean. By wiped clean do you mean the codeplug has all defaults and no previous user specific programming? If so, this would be normal but there is no such thing as a completely whiped clean codeplug. The CPS software does not allow complete removal of any section whereby you have to at least create defaults before it will allow you to delete specifics.
If you can't actually read the codeplug then that is entirely a different problem. If that is the case what specific model XTL2500 radio, what programming cable, and what software specifically are you using?
rescue161
KE4FHH
Hubert, NC
It sounds like he can read the radio, but that codeplug is blank. There should be at least one channel in the zone at the bottom. That channel references a personality at the top, which denotes whether the channel is p25, analog, signaling like MDC, encryption, etc. The frequency data and tone info is entered in the zone screen. Just make sure that the personality that the channel is utilizing reflects your parameters. So if you want to make the channel an analog for ham, make sure the personality is not set up for P25, encryption or other options that you do not want for that channel.
wgbecks
NE Wisconsin
Fivetenzen,
If in fact you can read the codeplug then why don't you post it either here or to a cloud drive with a link that some of us interested in helping you can take a look to see what you actually have.
fivetenzen
Northern
Ok 😂 Saved cmdrwill thanks. Ok I came home and read the posts and started over, different radio Same model. xtl2500 type 2. - Got in and could go to all the tabs and see what was loaded, wish I had marked the other radio! I think I gained a lot of respect for Motorola tonight- wow just a lot of information. So spent most of my time looking not changing. Changed the name. And tried to upload the data. It error out with it (cannot write radio without Advanced Keys). Ok. I found that, I had that loaded (Bonus). But lost - so I need to read and get better educated in Motorola before I wear out my welcome here. So where is the best place to start, if Motorola school is not an option. I will keep looking and see if I can find a training manual, I think I need to back up and get some Motorola basic skill. I do recognize things, but not wanting to get things so screwed up i have a paperweight. So is there somewhere I can read so I don’t have to be spoon feed - I thank you all for the inputs, advice and patience but think I really need to better educate myself before asking Question after question. Thanks. V/r. Steve. KC7KET 73’s. Good night
rescue161
KE4FHH
Hubert, NC
If you don't have the key that locked the radio, you'll have to use an ASK removal tool.
fivetenzen
Northern
Is ASK removal tool loaded in Advanced Keys or can I go down load it? I have a factory Motorola programming disk, will ASK be there? Is it a number code I would load into advanced keys -then have both programs up and running? you have an example of the key, how many numbers or letters ? I might be able to find that out ? Thanks
rescue161
KE4FHH
Hubert, NC
ASK is an iButton on a USB dongle. If you don't have that, you will have to find the ASK Removal Tool. It is not a Motorola tool, so it will not be on MOL or inside CPS.
fivetenzen
Northern
So it took me a little bit but have a dongle for the original radio programming and have been able to go change things - I have removed all the trunking programming on one radio and the display says unprogrammed. But with the dongle. Is there an easier way to go in and just remove the ASK, quickly - like just flip a switch or remove it. I had to go in and remove all the trunking Fred’s and talk groups physically. Or is that the only way. Can I just build a new code plug and reprogram my radios, without the ASK on it so it will be gone forever and I won’t have to mess with it Thanks in advance
fivetenzen
Northern
Nothing fishy. I’m trying to educate myself and very resourceful- I’ve done an awful lot for people with nothing in return- someone is trying to help me for once that’s all
marcotor
I ♥ÆS Ø
Sunny SoCal
If you have the dongle, in the CPS go to Radio Wide/General, and near the bottom of tab is Owner ID and Write Protect. Select None in the drop down, save the codeplug and write to the radio. That should clear the ASK requirement moving forward.
fivetenzen
Northern
Thank You !
