progrming the pro96 with arc96
ronw
dexter michigan
can some one tell me the purpose of the reband calulator,and how to know what to put into it. wash co. michigan.
ronw
ronw
dexter michigan
programing the pro96 with arc96
i appreciate the help i received on this site. iam using the arc96 program on my pro 96. the program is very user freindly. i do still however have a couple questions regarding rebanding in wash co. michigan. first about entering the reband table for the system here inwash co. from what ihave read on radio ref forums it seems like the reband table for mot 3600 systems is recommended. but here if you go to the m.p.s.c.s. data base,the new listings for the wash co. system is starting the transistion. the is a digital system and sites around wash co. are already digital. my ouestion is do i still enter the mot 3600 reband table or the 9600 reband table. also does it matter when i enter the table while using arc96 after freqs are loaded in the scanner for the bank being programmed or at any time . the last question is about the reband calculator. its purpose or is it necessary for what iam doing here. any help will certainly be appreciated.
ronw
Butelsoftware
Dayton Hamvention
The reband calculator is a tool to modify existing files. If you entered the frequencies from the database you do not use the reband calculator. Exactly which system do you want to program?
Gommert
Butel Software
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
ronw
It appears Ann Arbor-Washtenaw County Government System does not require rebanding as nothing in the notes indicate any need for reband. The two control channel frequencies are both 854.xxxx and all voice frequencies are at 854 or below that range, thus reband not required. However, as system is Motorola tables would be 3600 if used.
As for MPSCS, you need to use Reband calc for existing system and as the system is P25, use 9600 part for setting tables.
CadBane
I have the Pro96 too and I'm currently pasting the frequences from the database into folders so at a later date when I'm feeling bold I will try to upload them into my scanner. I'm definitely gonna need help doing it since in this case I'm stupid.
