ProScan: ProScan Error Code
crimacarlson
Minnesota
I run multiple different feeds using proscan. Almost at the same time I get error code 10 - unable to write data to transport connection. An existing connection was forcibly closed by remote host. This will come up on all feed around the same time and happen a couple times a week. Anyone else have this issue and know is it a proscan issue or would this be like an issue with broadcastify kicking it off?
belvdr
If its with broadcastify, how does one go about correcting it? I have emailed them to ask about it too. I run at 1000mbps fiber and run other streams and feeds both audio and video with no issue.
If you're emailing support, that's about all you can do.
ProScan
Software Provider
Ontario, Calif.
Did you see the link in post #3? Here it is agarin.
CKnobb
Central NY
Using Pingplotter, I have seen several issues over a couple months (at least) with the last few hops to the broadcastify.com servers. In fact, overnight it occurred again. Error code 10, sometimes for just 1 minute, sometimes for 10 minutes or more. There is definitely an unstable link between Chicago/Dallas/ Broadcastify hops. I am using Spectrum as my provider.
belvdr
Don’t rely on pings to determine if a path is good. So many systems block ICMP that it’s not a reliable source. You may have a device along the line blocking ICMP yet allow TCP connections with no issue.
