I have power cycled the scanner. No change.I would first power cycle the scanner
I guess you could do that. I never recommend that. All that does is replace the exe file with the same one.Can I uninstall and re-install the software?
Keys are handled via email only. It's usually same day when initially request comes in via email.I need the key
doctordialtone at gmail
I'll confirm thatIt looks like the UID display are shut off in the Uniden Settings menu.
Go to the Options - Logging tab then set the 'UID Column' to UID Before Lookup or UID #.I, am having this same issue on my SDS100 in Proscan. My UID is on and I can see it when scanning stops on active signal. But it does not show up in Proscan (History Logging). Am I not doing something right? Thanks.
I tried that, but it still does not populate the UID row in the "History Logging" tab.Go to the Options - Logging tab then set the 'UID Column' to UID Before Lookup or UID #.
Download and install 23.1 again.Bob, I changed from UID before Lookup and UID #. It did populate the UID row, but it seems to be showing "Hit Count" in that UID row.
