ProScan
AE1RH
I use Proscan running on Windows 11 ARM in Parallels. Works great.
jrl44430
ProScan_22_6 2/25/2024 1:58PM Application 8,770KB
This is the file that extracted.
Whiskey3JMC
Another Pesky Scanist
Simulcastylvania, TE
Downloaded with chrome. Same results. No exe file.
Downloads via Chrome are downloaded to your Downloads folder on Windows (C:\Users\yourusername\Downloads) Download will be a zip file, the .exe file is contained within which you'll have to extract from the zip archive in order to install Proscan
jrl44430
I am getting a zip file. I extract it and click on that file but nothing happens.
Whiskey3JMC
Disable antivirus temporarily & try the install again. If still no joy, right-click the icon then left-click Run as Administrator
jrl44430
Turned off antivirus and firewall. Tried administrator and still nothing. I am ready to give up.
Whiskey3JMC
Strange. If you're not seeing Proscan_22_6.exe as a running process in task manager then something is suppressing the install. You've tried restarting your computer since this first started happening?
fxdscon
¯\_(ツ)_/¯
Yes, Just seeing 6 not 6.exe.
In Windows File Explorer, click "View" from the top menu bar, then click on "Show", then be sure "File name extensions" is checked.
Do you see "ProScan_22_6.exe" now?
fxdscon
¯\_(ツ)_/¯
Yes I now see exe but it still will not open.
If you've turned off all anti-virus and firewall software, and tried all 3 ways to run that file (double click, right click and then click open, or click once to highlight the file and hit enter on the keyboard), then something in your computer is still blocking that installation file from running. It's very unusual that the "ProScan_22_6.exe" installation file won't run at all. You'll just have to trace down what it is that's blocking it, or try a different computer.
jMXj895RNrAnmiLMSyzg
Are you using Webroot antivirus by any chance? It's blocking the ProScan1.dll file. I reported the false positive to Webroot yesterday.
There was another false-positive last week with Win Security/Defender that Microsoft fixed.
VirusTotal flags a problem with ProScan 22.6 and 22.8 where three of 93 AV vendors reacted to it. Which means 90 found no problem, so it's likely they're false positives. (I skipped 22.7)
