mikeh
maybe i have a bad radio
i am lost
i am lost
In the TSYS menu for your San Mateo County system, how did you set the "T Tables" item? It must be "Custom". Also, you must enter two specific trunking tables:mikeh said:i am lost why this is going on i have all the settings right
and i get is a nice display and no audio
just white nosie.
Lo Chan Hi Chan Offset Base Step
380 559 380 482.000000 12.500
560 759 560 488.000000 12.500
Try loading V-Scanner folder 06 "CA Other". The San Mateo County system's talkgroups are in scan list 19. You may be able to hear that pre-programmed site from Fremont. If not, at least the T Tables settings will show you what you need to do.mikeh said:maybe i have a bad radio
i am lost
Marin County's digital sounds pretty much the same as what our system here in Manitoba sounds like for the RCMP digital tg's using the AGC on. You get that slight warbled sound. http://radioreference.com/modules.php?name=RR&sid=537DonS said:No, I'm one county south, but I can hear San Mateo County just fine. I can sometimes get Marin County's system, as well. (Enabling the Marin scan list now... we'll see if it appears in the stream... yep, sounds fine)
scnnr said:Marin County's digital sounds pretty much the same as what our system here in Manitoba sounds like for the RCMP digital tg's using the AGC on. You get that slight warbled sound. http://radioreference.com/modules.php?name=RR&sid=537
The audio on both the digital and analog tg's sound pretty much the same as what I am listening to with my pro 96/97 and 2096 here in Winnipeg.
Does Marin county not use pretty much up to date firmware in their digial radios with AGC set up thus making the audio in the system even. I guess what I am asking is have you tried to monitor Marin County with AGC off? to see if the warbled sound clears up?
[FONT=Verdana, Arial, Helvetica, sans-serif]Bulletin Release - 11/02/2007 - [/FONT]
[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]
GRE [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]- It has been brought to our attention that some new owners of the GRECOM PSR-500 Advanced Digital Scanner are experiencing problems with the radio's ability to properly decode P25 digital signals in some areas.[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]
Our engineers are currently working hard towards identifying and resolving this issue and a Firmware update will be available to resolve some of these issues related to P25 signals.
Note: All PRS-500 Advanced Digital Scanners are Firmware Upgradeable. Any future Firmware release or updates, will be available at our site http://www.greamerica.com/support. A user-friendly utility will also be available to help users update their PSR-500 to the latest version.
Currently there is no firm ETA on Firmware release. Once we have identified and resolved these issues, we will post updated Firmware release on our site.
We appreciate everyone’s feedback and support and ask you be patient with us until we find and resolve these technical issues.
- The GRE Development Team -[/FONT]
LEH said:Craig,
What does a 'matching CPU upgrade' mean? Send the scanner in for a new CPU or is this another code capable upgrade?
Thanks for the info, I'm am waiting for the upgrade and because my primary is one of the problem children, the sooner the better. But I'd also prefer GRE to make it right rather than make it fast.
bonus1331 said:Being proactive, I would assume a "sticky" would be appropriate when the upgrade is released.
Other than the start-up key configuration of "0, PGM"; I don't see much guidance for upgrade process in the manual.
Can see the confusion and "my scanner is dead" postings already;-)
Does the support page involve 'registering" prior to getting the firmware upgrade ala the Uniden support?
mikeh said:how is the audio on the Upgrade
LEH said:Craig and Dave,
I kind of figured the CPU update would be software as well, but a firmware upgrade and matching CPU upgrade made me wonder if there were both hardware and software changes forthcoming.
Like Strother Martin said in "Cool Hand Luke".
"What we have here is failure to communicate."
Or perhaps Winston Churchill.
"The English and the Americans are a similar people, separated by a common language."
cpunut said:I know of no hardware changes. To me "firmware" is something that is not easily erased. I know "firmware" used to mean plug-swapping or soldering a chip. Otherwise I think you could call this a "software" upgrade since it is accomplished from a PC to the radio's PC/IF port with the provided USB cable. I think that GRE's upgrade method makes the software not easily lost, so that is why I called it firmware. I am sorry for any confusion.
