JoeyC
Senior Member
Can anyone explain the differences in the Manual vs the Pause key on this scanner?
In one of my scan lists I have the main lineup of police channels on a trunked system programed. I have the primary and the secondary TGs of 7 divisions programmed, with the secondarys locked out. My intention is when I hear someone on a primary TG ask for a conversation to switch to the secondary TG and I want to listen to it, that I would hit MAN and press the down arrow button to move the scanner manually to the next object (the secondary TG). Most of the time when hitting MAN while the scanner is stopped on an active primary TG it will hold on that TG as expected. But occasionally hitting MAN does not stop on the expected active TG but moves to another one and holds (usually one many objects away from the one I intended to hold on). This usually happens when I am most anxious to hear that conversation on the secondary and it is then cumbersome to navigate to the object. (I am unable to duplicate my problem now that I am trying to. - Figures.)
While hitting PSE has always held on the desired TG, it is not possible to manually navigate to the next object using this method.
Just wondering if anyone has experienced this or perhaps has the reasoning behind why the MAN key responds as it does. Why a PAUSE and a MANUAL key?
