PSR-600 Mobile Install
mikebennett
Sherman, TX
Has anyone installed or attempted to install the PSR-600 using the DIN mount kit GRE offers?
I would like to do this but my in-dash space is 7 x 2 and according to the manual the radio measures 7.2 x 2.2. I thought the in dash spacing was supposed to be a standard size.
mikebennett
Sherman, TX
Williamb said:
Did you come up with any useful info? If not you may want to check this web-site out.
http://www.jottodesk.com/Comersus/store/comersus_dynamicIndex.asp
Thanks for the site info but I'm trying to mount the radio in the dash. I don't have much room to work with otherwise. I have a PSR-600 on order for work so I should be able to use that radio to verify it will go in the dash space. Thanks for the info.
ResQguy
Meh
I believe those dimensions are for the radio's cabinet size before you take it apart to use the DIN sleeve.
mikebennett
Sherman, TX
If that's true then it will probably work. I'll soon see..........
