PSR-800: PSR-800 and Windows 10
That's the stupid part. The .INF file is not the driver. The .INF file merely points to the .SYS file (the driver). The .SYS file comes from Microsoft.
Obviously MS does not agree. If you come up with something else .. be sure to let us know, cause from what I have seen in Windows 8 and 10 this is the only way to do the install.
Until there is a better way, without the workaround, here are instructions on how to make things work for the PSR800.
1. Go to Start Menu
2. Hold down Shift key and press Restart under Power menu item.
3. Under Choose an Option .. select 'Troubleshoot'
4. Select 'Advanced Options'
5. Select 'Startup Settings'
Press Restart
Press 7 for Unsigned Drivers.
Once restarted .. login as normal.
6. Go To Device Manager in Control Panel
7. Select Ports (Com + LPT)
8. You should see .. USB Serial Device (ComX) when your PSR800 is connected.
You can now install the driver.
9. Right click on 'Update Driver Software' under that Com Port above.
10. Select "Browse My Computer for Driver Software"
At the bottom, select "Let me pick from a list of device drivers on my computer"
11. Highlight "GRECOM PSR-800 Serial Device"
12. Click Next
13. You will see "Windows cannot verify the publisher of this driver software"
14. Select "Install this driver software anyways"
15. Click Close
The driver will now be installed as "GRECOM PSR-800 Serial Device (ComX)"
You can now use your scanner.
baayers
Pinellas County FL
For those of us upgrading from Windows 8 it is just a repeat of what we had to do to get it working before. For windows 7 users I can understand where this would be confusing as this is a situation you previously did not have to deal with. I upgraded this morning and can confirm that if you follow the instructions others have posted above everything works with no issues.
I updated my GRE-PSR 800 today. The library is 426. I used Windows 7,and had no problem.
This is not an issue in Windows 7, just potentially Windows 8, 8.1 and 10
It is also not a Whistler thing .. it is a Microsoft thing, and only cause they made a change in Windows 8.
MORSEMAN
Mesa, AZ
I have done this so far to 3 Windows 10 computers to get the PSR800 working with EZScan. I am repeating some of what has been said already but here it is in one place. I hope this helps someone.
Computers.Windows 10 installation of unsigned driver for GRE PSR800
1-Copy .inf file from the PSR800 CD to a folder on your computer
2-When you are signed in to Windows 10 as Administrator connect the PSR 800. It will then attempt to load the driver and appear to succeed but the driver will not be working at that point.
3-Load the Start Menu by pressing Windows logo key
4-Select Power and hit restart while holding down the Shift key.
5-A selection of Troubleshooting options will come up, select the Troubleshoot option
6-Another page will appear, select Startup Settings.
7-The next page will display several repair options, Select the Startup Settings to change the behavior of Windows Startup and then click restart on the next page.
8- A menu with 9 selections will appear. Select #7 or F7 to disable Driver Signature enforcement.
9 Windows 10 will restart.
10-With the PSR 800 still connected open Device Manager from the Control Panel. Select the Com port assigned to the PSR 800 and Right Click and select Update Driver.
11-Select Browse my Computer for Driver.
12- Select Let me pick from a list of Drivers.
Highlight GRECom PSR800 Serial Driver.
Select have Disk.
Select Browse and point it at the .inf file.
Select OK,
Select Next
Windows will display an alert saying that the driver is not digitally signed. (Note on one computer it did not display the alert but installed it anyway.)
Select Install anyway.
13-Check to see if it is working by Starting EZScan and selecting Scanner SD Card and select to set the Real Time Clock to Computer time. If it does it successfully you are good to go.
BeerNutz
Knoxville, TN
When Microsoft said Win 10 would be free, this had to bring up the caution flag. Come to find out, Win 10 spies on everything you do. Even grabs your home/biz WiFi password.
I know there are ways to opt out of all this spying but my Win 7 ain't broke so no reason to fix it.
AC2OY
Belleville,New Jersey
Holy Toledo that's some work around but thank you for all the hard work. That would probably take me a week to do. Not sure I'm going to upgrade now.
MFCJR
Thank you edmscan. I was stuck because I did not recognize the name of the port in Device Manger. You listing it by name (Com + LTP) got me through it. It went easy after that. I'm back up and running.
Thanks again,
Mike
Thanks again,
Mike
Glad to have helped you. It is not that bad at all and you only have to do it once.
radiomanNJ1
In the land of make believe
Are there men in black helicopters flying over your house now?
olepops
Danville,Il
It is not a problem with the EZScan program .. that works fine.
It is the USB driver ..
So .. follow this video on YouTube. My PSR800 is working fine .. with the USB driver installed. So .. the old driver will work.
I have rebooted and tested and all is fine.
https://www.youtube.com/watch?v=StkR3D2d5WI
The only thing ... the instructions are not 100% perfect, as Windows 10 was just released today. The version in the video is not 100% the same.
The main thing .. you need to get to Troubleshoot / Advanced / Startup Settings / Press 7 for Unsigned Driver and use the old PSR800 inf driver file.
I have attached the PSR800 USB driver .. in case you need it. I have also checked the 1080/1095 driver .. and they should be fine as well. The process would be identical. (This is now confirmed by Don Starr below)
i tried using the file you provided and it said i need one for a 64 bit system. have you got one?
Finto
Rhode Island
1. Go to Start Menu
Press Restart
12. Click Next
15. Click Close
I follow the first steps and it asks me for a software key any idea about what this is? I don't think I have that
AuntEnvy
Central New York
Is this just a driver issue with the 800?
I just started having an error code issue last night and now the scanner won't power up after reformatting a second card.
Is this simply a bad luck run of cards? Do they all of the sudden just stop working correctly while scanning, like mine did last night? Everything had been working fine with the win10 until now.
I'm inclined to think that my micro sd's just fizzled.
This is not an issue with the driver / file at all. It is as a result of a change that Microsoft did in Windows 8 on wards.
Even though people may complain about this to Whistler .. this is not really their issue.
All the file does is tells the system to use the default USB driver already installed in Windows.
Anything older is fine.
What is the error code number ?
The sd card issue is not Windows 10 related at all .. these things could fail, but it is very rare for that to happen. The only time I have had issues .. is when I physically dropped the card on the floor. It never worked again.
KR7CQ
Phoenix
I had no problems Don on the final production version of Windows 10 released today .... they work just fine. It is not rocket science and I posted the YouTube video to help the people that need it.
It's not rocket science, and I was able to follow the instructions and fix the problem easily, but you have to remember many people aren't as confident when it comes to anything beyond basic computer tasks. This whole thing could have been avoided by proper testing during the W10 beta stage and coordination between the manufacturer and MS. Not pointing fingers, but that coordination obviously didn't happen or didn't go well. There were months to work this sort of thing out, and it just didn't happen. It's sad that this will actually keep some from upgrading to W10 which has a lot to offer.
And to those worried about MS spying on you....pay attention during installation, and opt out of anything that shares your information. Done.
I happen to be a IT Specialist with near 20 years experience in support and application development, so for me it is second nature. Every time I have to help my parents .. I just take a deep breath.
But .. it is not a Whistler issue and really there is little they could have done .. it has nothing to do with testing. Really it is a one time .. 5 min procedure, that is very simple.
Is there probably a fix .. yes, but is it worth it, honestly no. It is well documented here. If you want to see issues .. go to the Uniden forum. This is pretty minor in comparison.
It is simply that MS made a change for Win 8 on wards that requires this and is not Windows 10 specific.
Re Windows 10, I do not care if MS sees what I do .. honestly, if they are that bored, then let them snoop all they want.
AuntEnvy
Central New York
Hey edm, thanks for the reply.
The code was 3-04, error writing to sd.
I tried a couple of times to reformat as per instructions but it won't take. Also tried reformatting/writing to a spare card but that dind't work either.
I'll have to buy a new card and try that I suppose.
