PSR-800 Backlight
Bronson24
Frostproof,FL
I Am Pissed!!!! I spent an hour last night go through EACH and EVERY Freq/TGID and made it where the backlight came on when someone keyed in...Now is there anyway to do that without having to go through EACH and EVERY channel to set that preference?
scannerfreak
Well Known Member
Indiana
Yep, Ctrl+A to to select them all. Then just make the change(s). It will change them all :)
IowaGuy1603
Jones County Iowa
If you would read the back PSR 800 threads almost all of your questions/problems have been addressed before.
detroit780
Silent Key
Michigan
Backlight
As in almost all Windows programs if you select the first row and hold down the shift key and click on the last row you want to change it will highlight all of them.
But you will spend hours doing it manually when you could have spent those hours learning how to use your radio first.
