PSR-800 Install in 2010 VW GTI
bgav
Central MA
Pics of ProClip Angled Mount (2010-2012 VW GTI) and ProClip Button and Clip Holder (Large) using the belt clip on my PSR-800.
For a totally covert install, I'm using a Diamond RH77CA mounted on the inside of the windshield along the right A-Pillar using a Valor BNCSCRS. It's no Austin Spectra or Larsen Tri-Band (I own both) but I'm very happy with the performance.
I can also patch the audio from the scanner to an AUX 1/8" jack to use the factory sound system, although the PSR-800 has excellent audio for a portable.
1150RT-P
Los Angeles, CA
nice. i had an 08 (generation before yours) for a few years. same setup - 2 door, manual. great little car.
bgav
Central MA
I originally was going to buy a used MkV GTI, test drove a few and loved them, but once I test drove a new MkVI, I was hooked. All are a blast to drive.
bgav
Central MA
Photos of the Diamond RH77CA and BNC suction cup mount installed on the inside of the windshield for a covert antenna. Please forgive the grimy windshield.
Thinking of upgrading to a Comet RS720NMO adjustable rear lip lip mount and Larsen tri-band.
1150RT-P
Los Angeles, CA
looks great, Brian. I may try something like this in addition to the NMO mount externally, for trips around town, then install the NMO for longer trips.
the only concern i see is if that curtain airbag deployed! I would hate for your passenger to have an antenna imprint on their face!
jambo
Phoenix, AZ
Wow. Now that's a very nice setup. Quick in/out with radio. That's exactly what I'm looking to do with my handheld. Thanks for the pics and idea.
bgav
Central MA
Thanks. Good point, I'll have to used an extension and relocate the antenna to a rear window when I have a passenger. Also a good argument to justify getting the Comet hatch lip mount :).
Thanks! I wanted something that was quick to setup and remove for theft deterrence.
So clean and discreet! Awesome.
Thanks! While the reception is a compromise from an external antenna, it works very well for what it is.
bgav
Central MA
@Ramathorne Universal Radio.
@Dann Thanks!
Sent from my iPhone 5 using Tapatalk
6Paul21
Florida
Is the power you are using by batteries only or do you have a 12V hookup. I tried this before but kept forgetting to turn the radio off & on and went back to the 500.
thanks Ed
