psr500 display screen
Highpockets
Toms River, New Jersey
I just connected to Don S on line scanner feed, when it stops on a trunk talk group it alternates between the talk group info then the cc channel info, any way to hold just the talk group info, and not show the cc info, i don't know if I could deal with the alternating back and forth for a period of time if I decide to purchase this scanner.
mikey60
Oakland County Michigan
Yes, this action is an option. You can also change the timing of how often and how long it shows the CC information.
Mike
dmadison
Woodinville, WA
Mike
What is the parameter name that controls the timing of how often and how long it shows the CC information?
Darryl
Landman
PROG, GLOB softkey, scroll waaaaay down to "LCD Blink On." This is the setting in hundredths of a second that the control channel will show. Be careful, this same setting also controls how long the system tag shows as it altenates on the display with a talkgroup ID tag and also how long the system ID shows on the display when in TSYS analyze mode. The item on the display that alternates with any of the above is control by the "LCD blink off" setting.
