PSR600 Browsing a Scan List
Ghawkman56
South Bend, IN
All,
I manually programmed my radio, Is there a process to perform a FIND function on a Scan list so I can review all the frequencies I have assigned to a particular list?
As always, thanks!.
satosi
Southern Ohio
In manual mode or program mode if you look through the objects in the scanner it will say what scanlist it's mapped to before the object number.
drdeputy
N Central FL/SW Missouri/Central Iowa
Review Scanlist contents?
Can you go to a particular Scanlist and review just what objects are in that list? Can you do that manually or with any of the software packages?
ScannerSK
Weld County, Colorado
With regards to the below question, yes to both. The right/left button changes the scan list and the up/down button manually reviews the stations assigned to that list. All of the programming software packages will show what stations are part of which lists.
Shawn
